1 - 15 of 15 Posts
My bike is a '80 CM400T and has a top fork bolt, and several other bolts and washers, as shown in attached photo. I'm pretty certain that my bike has a replacement front end, fork tubes, triple tree--probably as a result of a wreck--so I think that fork tubes are not part of original set-up. They don't match schematics at parts supply websites either. So just wondering if anyone can i.d. what model mine forks are from?
309235
Administrator
Probably need to see the rest of the forks, upper and lower, to get an idea if they are stock or not. The cap and hardware does not look familiar, but then I don't know much about the SOHC 400 series either
Looks like parts for the steel top bridge CB 400 Hawk front end that was also used on the 1978 CB 400 A models.........
Discussion Starter #6
Steve is right. attached schematic shows parts for '78 CB400T1 (parts #19, 5 and 6 match my parts). unfortunately i was hoping to replace top nut, but they don't seem to be available anywhere other that some Brit site that's selling new replicas at about $60 a pair. thanks all
309332
Was this type of fork ever used with a disc brake or were they all drum?
Used with both brake systems in 1978/79. The T1 is a drum brake, the T2 and A models were disc. The only difference between the drum and disc versions is the left slider.
1 - 15 of 15 Posts
