Hi,
I’ve been searching through the forum / manual and can’t find what im looking for. Do I need to remove the engine to work on the top end (piston rings, pistons, valve seals, etc) Or is it possible to just remove the cylinder head ?
Bike is a 78 cb400t
If so does anyone have instructions ?
Thanks as always ,
Joe
Don't know what manual you're looking at, check your conversations.
Actually top end work on the SOHC engines can be done in he frame. There are holes through the frame under the gas tank to access the headbolts. The factory service manual covers it quite well.
