I don't have the tool kit that came with the 1973 CB450 K6
I also am learning very quickly that my limited tool kit is not going to cut it.
Just had a question about socket wrenches (and I'm guessing wrenches in general) - do I need a metric or standard set?
Thanks.
Metric..... And, it's likely you'll want the "special spanner" for the oil filter as well... I'll edit in the link as soon as I find it.... Steve
Get deep well sockets, if you can afford them - a set with 8mm thru 19mm will cover most stuff.
Also a set of metric wrenches.
Also get an alternator puller-offer, and the oil filter nut wrench, both avaialble at MotionPro for a bit less than $10 each.
http://www.motionpro.com/motorcycle/tools/view/oil_filter___clutch_hub_spanner_for_honda/
http://www.motionpro.com/motorcycle/partno/08-0027
The cam chain tool will cost more - to break them I usually just use a Dremel and a small punch, but to rivet the new link, you will need some sort of tool, similar to this (it eill also break them) -
http://www.motionpro.com/motorcycle/tools/view/chain_press_tool_kit/
It's a bit salty, but what can you do??
Some guys try to avoid that cost by trying to do the riveted links with vice-grips or even ball peen hammers - I wouldn't recommend either of those techniques, personally.
And on any old motorcycle, you'll also need a variety of hammers of different sizes, and a rubber mallet comes in real handy.
Probably also handy to have a set of metric allen wrenches.
And some circlip (snap-ring) pliers, both inside and outside types.
