I thought it only fair to give a full explaination....
While a "wider" tire may work fine on a different wheel or bike, the relatively narrow 1.60 rims hold it so that it becomes a "taller' (not necessarily wider) mounting.... This gives a much more "rounded" area at the tread, but it's a smaller "circle" section....You may actually decrease the contact patch, especially in "leans"....
For cornering, you want a longer (wider) shallow arc, not strictly a rounder curvature necessarily.... The same size tire might be somewhat better on a 1.85 rim and fine on a 2.15 rim
You'll need wider rims to "Use" the wider tires to signifigant advantage...and now we're back to the weight aspect as well....
Steve
