I replaced the worn out throttle cables on my girlfriend's CM400T with direct replacements from Motion Pro. I routed them the same way the old ones come off but if I try to tuck them under the gas tank or anywhere near the frame they bind. Also steering left to right they will bind. I'm pretty sure they are routed incorrectly. I have them going from the handlebar, turned maybe 30 degrees out toward the headlight, then over the headlight bracket, behind the light, back toward the carbs above the lower triple clamp. Routed like this they stick way out past the tank just looking to catch on something. My clymer manual only says to route them the same as the originals, which in this case they were binding so I replaced them. My guess is that I shouldn't go behind the headlight at all and just go behind the forks near the horn mount and around to the carbs.
Long story short does anyone have a good description or pictures of how to route the cables?
