I have a Honda 74 CB360 I need to get new throttle cables, was curious if anyone has run a single throttle pull, still using the stock carbs.
Thinking about going that route just curious on others thoughts.
thanks in advance
Thats precisely what I'm doing on my 360. I think the return cable is an un-necessary safety feature. Be sure that the return spring snaps back to full close and you should be fine to run with one cable.
I figured it was for safety, are you going to be using the stock throttle or aftermarket one ?
