Yes, you can do this with the A model BUT you need to use the A model parts from a CM450A like the pistons and entire head ass'y. There's been attempts at using the manual trans part on the A model and while it works the power results are very poor.Will this work on the CB400A?
I was under the impression that all of the heads on the 400s and 450s were domed. Is this true or was there a flat top offering?So you used a 1977 400 head right? That'd be the pent roof head I believe. Interesting pairing with the flat top 450 pistons. Seemed to be the ticket for you though. Do you by chance have the marking from your head written down?
78/79 had a domed piston and a different cylinder head.I was under the impression that all of the heads on the 400s and 450s were domed. Is this true or was there a flat top offering?
Yes, from LDR's head thread:So you used a 1977 400 head right? That'd be the pent roof head I believe. Interesting pairing with the flat top 450 pistons. Seemed to be the ticket for you though. Do you by chance have the marking from your head written down?
Yes. Some later CB450's had a spacer and different jetting, but essentialy the same CV carbs.Would the 400 carbs work on a 450?
