Hello Twin friends,
Thanks to Longdistancerider for some early info on these two engine differances and his input to this site's knowlege bank. Hopfully this thread will answer this age long question as I don't think anyone has completed this conversion yet.
I'm converting my CB400t to a 450 using all existing 400 parts except cylinder barrels, pistons/rings and connecting rods. Note: You do need 450 wrist pins as they are larger @ 18mm
1st thing to address is that the upper case won't accept the larger 450 barrels. I took mine to 2 engine machining shops and they couldn't easily bore them out because they are not round to start with!
One advised to just use a die grinder and bore it myself.
I have a die grinder, so I bought a large 30mm x 12mm carbide burr and got to work on the upper case
