G
Guest
·Can any one tell me how to test the stator in my 71 cl450?
Thanks, David
Thanks, David
Take resistance readings between the yellow, pink, and white wires coming from the stator.robe338 said:Can any one tell me how to test the stator in my 71 cl450?
Thanks, David
Yeah, your coils are shorted to ground.robe338 said:Well heres what ive got.
Pink/yellow 1.2ohm
Pink/white .8ohm
White /yellow 1.7ohm
White to ground 1.1ohm
pink to ground 1.1ohm
white to ground 1.1ohm
I did this at battery ground
Only white and yellow had ac volts between them while running .121v ac
Sounds like bad stator. I guess ill add that to the list. Any suggestions on a good place to get one?
Thanks, David
