1 - 11 of 11 Posts
You shouldn't need anything like teflon tape if the rubber seal between the tank and the petcock is in good condition.
Two types of petcock.
One bolts to the bottom of the tank, using an elliptically shaped 'O' ring for a seal.
Other type screws onto a spigot, and I'm guessing this is where the Teflon tape might be used, although having said that my CL tap doesn't leak, there is a rubber O ring inside the captive nut on the fuel tap.
I have used teflon tape and it worked fine, I have also done it without anything and that works fine too.
I used teflon tape on my front brake bleeder screw to stop a really slow leak. Didn't have to use it on a new fuel tank petcock, just needed to crank it down quite a bit.
1 - 11 of 11 Posts
