Hello all. I recently became the proud owner of a 1974 CL 360 and after getting the bike home I noticed that I missed something in my pre-ride inspection.
My brake light won't come on....kind of.
It only works when the headlight is turned off. Once you flip on the head lights, the brake light stops functioning. Both front and rear brakes will cause the light to come on and off when the headlight is off, neither will make it function with the headlight on.
Has anyone else come across this before?
I am in the process of tracking all the wiring down, but I thought someone here might have come across this before and save me some time.
Thanks in advance,
John
Discussion Starter · #2 ·
Never mind everyone. A once over of the wiring found a ground cable that wasn't connected.
Now that I'm night-legal, I took it out for a spin and noticed that the speedo/tach and the high-beam indicator are not lighting up.
Luckily those won't keep me off the road.
A #53 bulb at the local auto parts store should fix that problem.
