Speedometer Rubber Bad
The rubber around the base of my speedometer (CL450K6) (I also corrected this to be speedometer, from tachometer) looks like burnt rubber inside. I peeled out chunks of the hard black material (maybe had been black foam?) and plan to glue it back on the steel bottom, then install the rim on it that I had cut in the past and join the ends together with copper wire. Any other ideas?
