Hey guys, trying to take out my cam followers for inspection but can't even get the damn lock nuts off! When I turn the lock nut the cam follower just turns with it. Have I stripped it? what gives.
Guess it seized up on you.
Assuming you have the head on the bench, carefully rotate the cam until it's loose (no tension on the "lifters").
Then turn the adjuster shafts until the tappet is as loose as possible.
You should be able to take out the 4 cover screws on each end and pull/pry the cover (with the frozen adjuster shaft) out of the head.
Then you can get the offending adjuster shaft in a vice and break the nut loose.
You'll at least save the cam "cover" (bearing) this way - new adjuster shafts are easy to find.
Thanks a heap! things seem so easy in the text until I actually try and follow them. :| but i got em out now
