1 - 1 of 1 Posts
Hi, I have a 72 CB350 with VM30 carbs. I noticed that the right carb’s slide was sticking. When I give it 1/4 throttle the slide dies not return to idle position. It’s slightly higher position. If I give it full throttle, it returns back to the original position. I’m trying to re-route the cable - thinking that it might be a linked line. I tried adjustments at bothe the carb side of the throttle cable and at the handle bar. I’m not making any headway. Can someone provide some insight on what may be the cause? Thanks!
1 - 1 of 1 Posts
