Steve -
Is fork width (tube-to-tube) on a CL450 (K4) the same as disk brake CB450??
(Later Pinch-type clamps)
I believe so....Same stem and bracket, and top bridge part numbers (aren't they?).... Steve
Not sure, Steve, that's why I asked.
The fiches are confusing in this instance......
Bill, I still believe they are virtually identical ...width, offset, everything.....(once they changed from the "top bolt" style)... Since the "keyed" endnut of the axles positively "places" the wheel centerline, and both the 450 drum and disc wheels will exchange (into the 450, 500/4, 550/4 and early 750/4) the width almost HAS to be identical throughout those bikes....( the 500 and 550 do have a different offset, but identical width).... I've never actually measured, but have swapped wheels/forks (and sometimes trees) between all those bikes.... Steve
