Gang
I'm gonna strip my SL down next week with the intention of taking the frame and associated bits to be powdercoated. Before I do, I need to yank out all of the various bearings and bushes out, which won't be too much of a problem . . .
. . . but I wanna get the steering stem lock out without screwing it up. I've knackered one before trying the same thing on another bike, so before I make the same mistake again, can one (or some) of you give me a some idea how to remove the lock with the minimum of fuss/damage?
Thanks.
the-chauffeur said:
Gang
Thanks.
Remove the little plastic cover, insert the key, turn it and pull out the lock - no big deal.
Thanks Bill
I think I over-complicated it last time because I didn't have the key . . .
Which reminds me. Is the ignition key likely to fit the stem lock? (I have a strange feeling it won't).
Normally I'd check, but the bike doesn't get here until Wednesday.
Neil
I think I can safely say yes, both locks use the same key and they will have the same ID numbers on the face of the cylinder.
And a big thanks for explaining how to remove the darned cylinder. Dufus me didn't think of insterting and turning the key as critical to the process :?
If the ignition lock is the same as the steering lock (original) then the key will fit and remove it.
Beat to the post.. :p
If nothing's been replaced the same key should fit all the locks on the bike.
By the way, welcome to the group. Here's some good information to help get you started.
viewtopic.php?f=4&t=3797
