1 - 2 of 2 Posts
Anyone done this? If so lemme know how. I absolutely must put one on this bike. (I ride like an animal)
Yes, It can be done....In several ways....... For the easiest way, you need to obtain a complete set of 350 damper components (all 11 parts), an early 350 lower tree (for the correct stem), and a "spare" 360 lower tree into which you transplant the 350 stem.... Once the fabrication is done, it will look and perform like it was "stock" ....
Another option is to fabricate brackets based on the 305 "shock type" damper similarly to the proceedure I used to mount one on my "vintage-look CL 175".....
Most aftermarket "screen-door closer" types can be fitted as well, but are expensive and often present clearance issues....
1 - 2 of 2 Posts
