bike had not been started in 10 years.but when it was stored the tank and carbs were drained.i put new plugs new battery and new fuel lines and it started right up.i drove it down the road and the yard for about half an hour and ran great.the throttle stuck a little bit but wasnt too bad.so the next day i go to start it and it wont.the chamber is not geting any gas.i pumped it and turned it over a hundred times and the plugs are still bone dry.the carb bowls have gas in them and the filters in the lines are full.so i think im getting gas to the carbs.if any of you guy could suggest anything i can try to get fuel to the plugs that would be great.thanks
