So i put my 360 back together and tried to start it by using the electric start. After just a few turns it fired up and ran for probably 10-15 seconds. Then did it again a few minutes later and started up again for about the same. After that I havent been able to start it again. I seem to be getting getting fuel to the carbs when I open the drain plugs on the bottom of the carbs. Im not sure about compression yet I know it has some but my tester seems to not be working right now. I just replaced the coils with mikes xs and I have had issues with them getting spark sometimes but then a few minutes later only one side will be getting spark. Any ideas why I am only getting spark sometimes and is there any things else to look for to get it up and running?
thanks
thanks
