1 - 2 of 2 Posts
i have a '75 CB360 and the electric starter half works. it runs but doesn't engage the engine. i'm thinking it may be that the magnetic switch (aka starter solenoid, right?) located near the battery must be bad. if that switch is bad, then it wouldn't move the cable attached to it. i'm assuming that the other end of that cable is attached to the starter motor armature... if that switch doesn't move the cable, then the armature wouldn't move and that starter wouldn't mesh with the engine?
am i on the right track? how do i test this?
i appreciate any help you all can give me!
shaun
1 - 2 of 2 Posts
