I was considering taking off the solenoid as it looks like garbage and unnecessary as i pulled off the e-start. I'm just curious where the other 2 wires (other than the beefy one to the starter motor) lead to. Looks like the ignition and .......
I'm assuming it's safe to disconnect the two other wires at certain points and pull the whole unit out?
Disconnect the short heavy wire at the battery terminal..... unplug the two thin wires (black wire will be "hot" when the ignition is on, so tape it so it can't short out to the frame).....Remove solenoid (part numbers 5, 9, 10, 11) from bike.....Done....
the other (Red/Yellow) wire just goes to make a ground at the handle bar switch when the button is pushed, trace it from the solenoid up to the switch
