Rebuilding starter clutch and need to know if the rotor bolt is right hand. That is remove by turning counterclockwise.
Thanks.
Nope it's a normal bolt. Just use a strap wrench or something to hold the rotor in place and loosen the bolt.
If you have access to a impact wrench, that will work . I struggled with mine on my 450K6 until I used the impact, came right off.
