I have this NOS head that I want to start using and yesterday I looked at the exhaust ports and noticed the shape. Are they always so small compared to the exhaust and exhaust gasket? Could be that I am just used to seeing them covered in soot.
BTW: Judging from the combustion chamber it is not a 250 head
Very nice score!
The basic answer is, "Yes."
According to CMSNL a CB head is the same as a CL head.
https://www.cmsnl.com/honda-cb350k4-super-sport-1972-usa_model433/head-cylinder_12200287100/
According to their site it fits:
CB350K4 EUROPEAN DIRECT SALES
CB350K4 FRANCE
CB350K4 GENERAL EXPORT / KMH
CB350K4 GERMANY
CB350K4 ITALY
CB350K4 SUPER SPORT 1972 USA
CB350P GENERAL EXPORT
CB350P0 GENERAL EXPORT
CB350P4 POLICE TYPE GENERAL EXPORT / KPH MPH
CL350 SCRAMBLER 1968 K0 USA
CL350 SCRAMBLER 1970 K2 USA
CL350 SCRAMBLER 1971 K3 USA
CL350 SCRAMBLER 1972 K4 USA
CL350 SCRAMBLER 1973 K5 USA
CL350 SCRAMBLER K2 GENERAL EXPORT
CL350 SCRAMBLER K3 GENERAL EXPORT
CL350 SCRAMBLER K4 AUSTRALIA
CL350 SCRAMBLER K4 GENERAL EXPORT / KMH
CL350K3
CL350K3 JAPAN
SL350 MOTOSPORT 1969 K0 USA
If someone could take a picture of a standard exhaust port then that would be very helpful. I have some extra heads but I think that most (if not all) are modified. I will do some digging in the stash, later today.
So I looked at all the heads in my stash and I was able to find two heads with unaltered channels. I compared them to my NOS head and the channels on that actually do seem a little but smaller.
To compare the surface area of the channels I used an exhaust valve to measure.
On the used head the exit of the channel is basically the same size as the valve. I can just fit the exhaust valve in the channel but it is a tight fit and I can't slide it far into the channel. Only one millimeter or so. On the NOS head the valve does not fit into the channel at all.
So my NOS head indeed has smaller exhaust channels. Towards the valve they look the same so I modifying them will be easy. Inlet channels also look the same. I still need to figure out if I need to enlarge them or if then can stay like this. I am building a tuned engine and from what information I have found, the consensus is that enlarging the outlet channels on a CB350k is not needed and actually does not help. I found some nice information about tuning these engines from thrustworthy sources (succesfull and well known racers) on this page: Honda CB350 Road Racer FAQ, Engine Modifications Page
Thanks for that link. Odd that they would be differently sized. I wonder if there are differences between years of production; for example, isn't the duration/lift of the cam slightly different between 68/69 and 70-73? That may be a false memory...
That is correct. For the CB/CL 350 there are basically two styles of cams: Early style fat cam design and late style skinny cam design. Really early versions of the fat cam design have a hotter profile but only the really early ones. I think K0 but maybe not even all K0 bikes. Most fat cams have the same timing as late style skinny cams.
All the heads that I have have different casting ID's and numbers on them. I guess they used quite a number of different templates.
