1 - 16 of 16 Posts
Hello all. I have plans for a trip next year with some buddies which will be around 800 miles, mostly highway. I find the gearing on my bike is fairly low for the highway, though I realize it's just a 450...I'm hoping to get a little better top end speed to reduce the rpms. I'm wondering how much bigger I can go with the front sprocket as my rear doesn't look like I can lose any teeth.
thanks,
Jeffe
What number of teeth front sprocket is on it now?
Many of us with 450's run 17 tooth counter sprockets, about as big as you can go.
A bit more clutch-feathering from dead stop, but really cuts down the vibration at cruise......
(I just didn't want to tell him to go up until I was sure he wasn't already there) LOL... :lol:
Quote corrected for INTENT, not specificty.......LMAO!
it is stock. Thanks for the input. When you swapped, did you have to change your chain, or could you get away with moving the wheel in a bit?
edit: so just a question, since I changes my rear wheel to a cb360 one and have the stock rear sprocket on, it just looks like I can't lose any teeth from it. I'm not 100% on that, so if it's possible do any of you know? It would be easier to lose some teeth so I don't have to buy a new chain...if moving up 2 teeth in the front would require a new one that is.
What is your current toothing? (front and rear) and are you running a 360 swingarm?
Technically, BOTH sprockets and the chain should all be exchanged for new as a unit.....
yeah I'm running a 360 swingarm and wheel with the stock 360 sprocket, which I think is a 38t sprocket from the factory and the stock cb450 front sprocket which is a 15t. And yeah I know they should both be changed, I'm just trying to find an optimum or at least common enough gearing for highway and city. I would say 90% of my rides are in the city, but for the highway rides I really need higher gearing because my state has 70mph limits which means everyone is doing 85.
The 360 swingarm is longer and extends the wheelbase....which lowers the bikes rear end a little.....Overall weight reduction is probably minimal (more arm, more chain, less brakes, smaller diameter axle...etc...)
I went with a 17t sprocket and I really enjoy it. It takes the vibration down so much from stock. I do think though that the best combo would have been to add to the rear sprocket two teeth and stick with the 17 up front. But that would have been just a hassle. The acceleration is only an issue on the top end, where it would be anyway, but in city traffic where a major road varies from 80mph to 45mph and back up, I actually wouldn't have minded slightly higher gearing.
IF a 15 Tooth sprocket is stock on a CB-450 (I have a 1971) then what is stock on the rear?
I'ld like to run a 17 / 16 on the front and one tooth small on the rear.
Suggestions?
Chain length?
TIA
1 - 16 of 16 Posts
