I’ll be cutting the wires on my CDI unit to install a new one from cdimagician. What do you recommend for splicing the wires? Are crimp connectors and liquid tape good enough?
I’ve only ever used butt splices and electrical tape/shrink wrap, which has worked OK. I hear that tinning, intertwining the wires, soldering them together and then putting shrink over the top is the more correct way, though.
Crimps are better than solder. When you solder a wire the molten solder wicks up the wire strands. A stress riser is formed where the solder ends. If the wire is not mechanically supported any vibration can cause the joint to fail. You never see solder connections on airplanes. A proper crimp tool and a favorite set of splices and compatible bullet connectors is a must have for the home wrencher. Honda uses a 3.9 mm bullet connector.
Unbeknownst to me, I wasn't doing it completely wrong after all I third (fourth?) the Vintage Connections recommendation. Their crimper and barrels make even the noob connections I do look good.
