1 - 1 of 1 Posts
The 73 CL350 I'm working is all good now but front brakes were a bit weak so I pulled to inspect/adjust. After taking brakes out, cleaning stuff up, and doing some research, I found that the speedo gear the spiral gear meshes with is missing completely. This explains speedo not working.
Question is will this have any negative effect? All seemed to work fine without it but wasn't sure if it affected anything with wheel tightening etc. If not I'll leave as is and notify owner of the issue.
Thanks ahead of time.
1 - 1 of 1 Posts
