It's not running well. I can't rev it past 40% throttle.
List your setup.
Strip them carbs off and make sure all the jets are clean. Make sure they are stock. Depending on air filter and pipe they may be bigger than stock. Don't get too crazy just get some different guage wire and poke the holes. They get gunked up. Lol. Dirty.
You would be suprised on what previous owners do to jets. It is not understood by many. Could be way off could just need a few adjustments.
Jetsrus.com has everything you need.
Spray the orrafices with carb cleaner and air if you have it. Them slap then back on. New fuel, new plugs.
If you don't have full throttle response then start looking into the electrical. It may hesitate and what not but you should get to high rpms if the mains are even close.
Sent from my Pixel 2 using Tapatalk
