'75 360: new coils, wires, resister caps and NGK B8ES, but condenser is original. I've been working on it on and off since last spring when it was pulled out of a barn. While dinking with it last fall, the new spark plug went bad on the right side so I replaced both. When I did, I'm 75% sure that I replaced the right coil at the same time just in case (I had inadvertently ordered twice the coils and caps so I have spares).
Now that the weather is warm, started it yesterday and initially it wasn't running on the right side, then decided to. Then today it won't spark at all on the right side. I switched plugs around and confirmed that the plug is bad. That's twice now. Again, I haven't put hardly any miles on this thing yet.
What causes two plugs to go bad so quick on the same side? Do I try another brand of plug? Put the last new coil and caps on when I do? Replace the condenser even though the points aren't arcing? Auction the whole thing on eBay for $50? Give it to my brother? Soak in gasoline and light on fire? AAAAUUUUUUUUUGGGGGGHHHHHH!!!!!!!
