I'll say it again. I'm the best advertisement that the PB Blaster corporation has ever had! That stuff gets into places and unlocks things that have been stuck for decades. Plus if you soak it in the PB then you won't have to worry about rust for a good long while. Just keep it away from rubber, ALL o-rings, and most plastics. Especially foam.
It successfully unlocked a piston/cylinder/crank that had been outside since around 1983, with no head on it and full of water. Through Illinois winters... It was on a Yamaha CT3. The engine still turns over despite being outside, without a head, ever since. Before that, I had tried gasoline, diesel fuel, tranny fluid, WD40, Kroil, and various homebrewed mixes of all of them. Even tried a 2x4 with a 5 pound hammer with no results.
Good luck with that advancer.
