I have just finished rebuilding the engine on a CB175 K4 (UK model) and whilst it runs nicely and all the electrical parts, lights, indicators etc are working I have found there is a 5A draw on the battery when the ignition is turned on, the battery is new and reads 12.5 volts all the time. The alternator appears to be pushing out a good voltage but as it should only supply 1.8 A even when in top condition it is loosing the battle with whatever is stealing my electricity. It still has the original selenium rectifier which l believe is working OK as the output waveform has been checked by my neighbour with an oscilloscope, (interesting but not fixing anything). So far I have disconnected all the wires easily got at with no change to the current draw. Note the UK bike does not have a voltage regulator but should switch the alternator windings when the lights are used.
So have you seen this sort of thing before and any thoughts on where the electric thief is hiding?
