I love Hondas. Always have. Owning my own Honda CB is something I have wanted for a few years now and I guess you can say my dream has come true, in a very misconstrued, backwards, ironic, kind of way. Once I was financially able to buy a CB I started casually scouring craigslist for a deal on a CB 550 or 360. I wanted a rough bike; make it into a project, so it would be my own. Well, I definitely got what I searched for.
I finally found it, a 1974 CB 360 for $500. For two years it was stored under a tarp, completely taken apart, except for the motor. The guy I bought it from said it ran perfect when he took it apart; he just wanted to clean it up. It never got put back together. Everything was rusted, dirty, and wet. The motor, although together, was full of old oil, water, and rust. The motor wouldn’t turn over and you could see the valve was open. A bit skeptical, I bought it anyway. If things went south with the motor, figured I could part everything out and make my money back. PLUS it came with a bunch of extra parts.
I knew this was going to be a challenge considering I have only worked on dirt bike motors (I own a 2010 CRF 250) but I figured it couldn’t be THAT much different. Ill spare you most of the details and give you the highlights of the tear down and rebuild of the motor.
-Everything was covered in rust
-PB blasted the valves, and they broke free fairly easily
-A bucket of diesel petrol and brillo pads became my bestfriend
-Cylinder was rusted and pitted – Honed it out – looks brand new
-Piston rings were seized – bought used pistons off ebay for $40
-Attempted to clean the cases and cylinder in the bathtub, then the dishwaser, and then scrubbed them with steel wool, no dice. Ended up getting them sandblasted.
-Used high temp spray paint to paint the top end.
This wasn’t an easy task! If anyone has questions about anything feel free to ask.
After being sandblasted
Another issue i ran into, was the triple tree clamps were broken - I bought a set of 1976 CB400F triple trees which worked perfect for the forks, but the headlight and gauges will not mount up now, which i'll just have to figure that out eventually, but shouldnt be too hard.
After buying a bunch of missing bolts off ebay we got the motor in the frame and the new handlebars on.
I attached all of the handlebar controls, having to drill holes in the handlebars, not difficult. Helped to wrap all of the wires in electrical tape to help maneuver them through the bars. Also, my exhaust was really really rusted and I was missing the mounts, so I decided it would be easier, and better looking, to just wrap the headers with exhaust wrap and run straight headers.
Everything should lead to it starting but my ignition coils are bad, so I ordered a set from Mikes XS so hoping that is gonna work.
Planning on using the anti-gravity battery, since I plan on Kick starting it as much as possible.
A lot of work to go! i'll post more as the progress continues!
