I know that most here worry about using a torque wrench for most bolts on our engines as the FSM offers torque values for practically everything, but I learned long ago that many situations - particularly the 6mm variety - are simply tightened enough by using a good "feel" for both general tightness and the fragile nature of 6mm bolts on these engines. I've never used a torque wrench on 6mm bolts on engine cases, cam chain tensioner housings, torsion bar retention bolts, shift levers and many others... it needs to be tight, but not so tight that you risk damage, and if your torque wrench has an error factor that is more than you realize... you can get in trouble in a hurry. Obviously, the larger and more important bolts and cap nuts on lower cases and cylinder/head studs need to be properly tightened with a torque wrench as our ability to "feel" is more suspect as the tightness factor increases. I've never had anything go wrong while using that approach and after you work with the strength of Honda's 6mm bolts for a while, you develop a good feel for how much they can tolerate before either stretching them or breaking one off.
