1 - 2 of 2 Posts
Hi all
i have a cd 200 / cm 200 for you guys across the pond, i have recently completed an engine rebuild with rebored barrels and oversized pistons, my problem is i noticed smoke/steam coming out of my crankcase breather hose as well as bubbling white liquid, is this bad? or just condensation burning off from the engine being appart for the rebuild ?
thanks in advance
Paul
I believe the crankcase breather system on that bike has a separator box to accumulate oil vapors, though I'm not sure if it's used on your model. If it has one, did you check and/or drain the box after the rebuild?
1 - 2 of 2 Posts
