Discussion Starter · #2 ·
Would this be caused during installation? The gouge is at the base, not quite on the side against the wall. Hoping I can still use this slide.
If you file the raised edges of the gouge flat, it seems like you should be able to use it. New slides with diaphragms aren't cheap.
Reactions: RVACB350
