Hello Ladies and Gents. I haven't been around the forum for some time since selling "Herbie" the 1980 CM200 a while back to a friend. I've since had an SL350 land on my lap and I'm working on getting it running and could really use some help. Here's the scoop.
I drained the gas tank and refilled it with 2 gallons of fresh 87 octane fuel. Removed both carb bowls and dumped out the old gas. A while back on a weak attempt to get it running I removed both carbs and gave it a good cleaning but this time around I didn't do this. That was probably 2-3 months ago.
With the choke on fully it fired up in about 5 kicks. Sweet. Purred like a kitten actually but then I realized only one exhaust header was getting warm. Left side was hot, right side was dead cold. With the bike idling (on the left cylinder) I removed the right side spark plug wire and promptly got zapped but I managed to stick an inline spark tester and verify that it was getting spark. Next I moved on to fuel. I sprayed starter fluid straight down the throat of the right side carb and saw zero change in engine speed or header temp.
The next place I went was either bad spark timing or valve clearances. The service manual I have states they should be .002" and .004" (I don't recall if those are intake or exhaust). The smallest shim I had was .006" so I rotated the crank to set each at TDC and verified the tappets were loose and attempted to put the shim gauge in the gap. No go. So they are all less than .006" and judging by the amount of slop I don't suspect they are less than .002" so I think bad valve clearances are unlikely. Perhaps someone here can shed light otherwise.
Next I did a compression test on both cylinders and they were right around 150 psi by the time I got tired of kicking. Manual states 150-170 is normal and since this was done fairly cold I called that a pass.
Then I opened the points cover and adjusted the point gap where the contacts open and close. Manual states they should be 0.3mm to 0.4mm so I adjusted them where the 0.3mm shim had very light drag and the 0.4mm caused visible opening to make it fit. Next I checked for spark timing by attaching a multimeter across one set of points and turned the meter to test continuity. I cranked the engine through its paces and rotated the whole plate until the points opened right at the F mark (which I think means the right side cylinder). In hindsight, I only did this for one set of points but I can't adjust them independently so was this okay?
I checked the spark plug gaps upon reinstallation and found them to be in spec. Manual said .028"-.032".
I buttoned everything back up and gave the bike a few kicks (took more than 5 this time around) but it fired up and alas... Still runs on only the left cylinder. Same symptoms. Has spark, starter fluid has no effect. No backfires no nothing.
Can anybody shed light on what is going on here? Is the right side carb flooding the engine and that's why it doesn't run and starter fluid (more fuel) has no effect? When I put the fresh gas in I watched the fuel go through the filters and made sure the flow stopped once the bowl got full so I know the float valve works. Maybe a float height issue?
Any help would be great because I'm stumped.
Thanks in advance.
-Harrison
Thanks in advance.
-Harrison
