I am replacing my old fork tubes with new ones from Franks and have a question on the bottom of the old tubes. There is a screwed in insert in the bottom of the tube where the oil lock piece fits in on the old tubes. I am not sure if this is a one piece insert or two piece. The end of this insert is notched on both sides. The tube end where the notches line up with appear to have been dinged in on purpose on both tubes so the inserts won't come loose on their own. Is this how it came from the factory or is this something a p/o has done? Is this something I should do on the new tubes when these inserts are re-installed? Thanks in advance - dave
