I'm now at the point where I'm putting the top sections back onto the engine, and I seem to have run into an issue that I hadn't foreseen - the camchain has remarkably little slack in it to the point where I can't find a way to reinstall the cam sprocket without putting into the chain loop with only the cylinders in place, and then passing it upwards through the two top sections and gaskets. There also seems very little wiggle room once the chain is on the sprocket with which to align the lower and upper timing marks . . .
Does that sound right? I'd've thought there would be enough chain to lift it up 'n' over the sprocket (whilst the camshaft is out), but I just can't find the room.
And don't talk to me about installing the end caps (to maintain tension), winding the engine backwards 90 deg, uninstalling the caps and only then attempting to install the rockers. I don't recall reading all of those instructions in the manuals . . .
