Is there anything special about the washer that sits behind the screw head for the drain screw on the older models? I have a nagging drip from the screw. Replacements seem out of stock. This is the smaller drain screw and not the one with an o-ring. Tried one of those - too big of a head and wasn't sure the O-ring would be wise behind the existing screw which currently has a flat washer.
I think it is a small aluminum crush washer. Try to find a small copper washer that size.
Thanks. Copper washers that small may be a challenge, but then again so are the replacement screws.
Copper and aluminum washer assortments at my local Ace Hardware (y)
