I'm having charging issues with my '74 cb360. I pulled the alt cover and there is oil pouring out. is there supposed to be oil there?
Oil enters the left case via the main bearing and exits through a small hole at the bottom, returning to the sump. When you strobe your timing prepare to get a bit grubby ;)
There should be oil there, but it shouldn't be "pouring out" unless you are on the side stand.... Some will come out when on the center stand, but it should be relatively minimal....As Leethal warns, it does splash a good amount out when running/timing the bike, even on the centerstand......
