Hi
Just a really basic question. I had the tank off my CB350 K4 and had it running for a few minutes on a dummy petrol tank. After tweaking the carbs I turned the ignition off and found that the Coil was quite hot to the touch. The bike had only run for a few minutes, and I was surprised how hot the coil had become. Obviously you don't really get to see the coil when the tank is on. As I haven't had a chance to run the bike I don't know if there are any electrical issues as yet. Should the coil be hot after only running the bike for a few minutes?
Cheers
Mal
Double check you rpolarity.
They will run very hot if wired in reverse.
I've seen "very warm" coild, but never hot, if it's uncomfortable to the touch I don't think that's right, very warm though, yeah, seen it a lot.
If it was summer i would be out there running the bike and burning my hands checking the coil, TY winter you are good for something.
They will get hot (and burn up) if the key switch is left on without the engine running. A few minutes won't usually damage them, like when setting static ignition timing, but a longer time can fry a coil. They will get warm while running, but it's no big deal.
