So in my build I'm restoring as much as possible and upgrading where I can when it doesn't really affect the vintage look. 1970 CL450. My forks are in great shape.
Earlier in the forum I was told the 73 and 74 models got the newer forks (I have the spring on the outside style). I'm a little overwhelmed with everything else I have to work on in the build so I'm hoping for some guidance. I'm assuming I should change mine to the newer ones. I've already got my triples at the powder coaters.
Is there anything else I need besides the 73/74 forks (triples, etc). I assume the wheel/drum brake/fender are the same so should be no problem bolting up
I already ordered tapered bearing kits for my year - will that work with 73/74 or do I need to order a different set for that
I found a set of 74 forks on eBay but they are slightly pitted/rusted for $125 shipped. Wondering if it's worth cleaning them up or is it better to get new tubes from Franks Forks. Not sure how well they will clean up and time is also an issue for me with the build
Are there fork sets from other bikes that are the same I can use so I can expand my search?
Thanks-
Thanks-
