Hi All,
I was putting the bottom and upper end crankcase back together and, unfortunately, I over torqued all of the 6mm (i.e., 8mm bolt head) by using a torque wrench improperly ultimately breaking one of the longer bolts. I was able to get the broken shaft out pretty easily, and I was very thankful for that.
My questions are do I need to replace those over torqued bolts? Should I be worried about any damage to the threads in the crankcase? Can I get replacement bolts from the hardware store or should I get used ones that came off another cb350 on eBay?
Thanks in advance.
Thanks in advance.
