I am looking for good rubber protection for my CM 400
I have fitted the CX 500 front fork and now I found out that here in Holland it is only possible to order the front fork harmonica's for a yamaha xg 250 trigger front fork.
Does anybody have the inside measurements of this front fork, so I can be sure they will also fit on mij CX-fork??
I found them on this horrible website:
I don't have a complete assembled 400 front end handy. I know the fork tube diameter is 33mm. Now you need the diameter of the top of the fork slider and the extended length of the fork between the bottom triple and the top of the slider.
Getting one too long will cause the fork travel to bind during compression
I have these on my cb400t, the measurements seem similar. I had to stretch them slightly to get them onto the fork bottom. They don't fit perfectly into the fork shroud on top but that is minor.
