1 - 1 of 1 Posts
Just when you thought it was safe to go back in- Shark Bracket!
Works great. Sturdy. Top of the food chain in bracket technology
Her vital stats.
3.75" from front of fork to middle of headlight mounting hole.
2.30" top of clamp to the bottom of clamp as she sits on the fork
8mm and 10mm hole for headlight bolt ( spacer included)
32mm to 58mm forks ( select size in drop down menu)
Split size also avaialbe-just pic the size you need in drop down menu
High quality cnc machined headlight brackets these high quality contrast cut headlight brackets are made from cnc machined t6061 billet aluminium and have adjustable arms which allow for different width headlights.
The fork clamps are 2 separate pieces so they can be mounted onto the forks without having to drop the forks down from the triple tree (yoke).
Ideal for all cafe racers, streetfighters, project bikes etc.
Specifications t6061 cnc machined aluminium
2 piece fork clamps fork mount diameter:
304 grade stainless steel allen bolts colour
black anodized with contrast cuts package includes
2 x headlight brackets
Website link: https://www.speedmotoco.com/Shark-Sharky-Headlight-bracket-Motorcycle-p/sharky-.htm
1 - 1 of 1 Posts
