1 - 2 of 2 Posts
Looking for some advice on our shaky dyno graph.
Bike Details:
Cb175 bored 1st over
Keihin PE24 Carbs with port-match intakes
1.5" custom exhaust
Dyna coil
The bike rolls through the RPM range just fine on the stand, but stalls a bit about mid throttle under load (you can see it in the graph), the clears up and takes off. Needles are set to second from bottom. 102 main jets. Stock D8HA plugs.
1 - 2 of 2 Posts
