I'm trying to set the timing, running a Charlie's Place electronic ignition. I've watched the video, I understand the process. I have my test light in place on the yellow wire and my goal is to adjust the positioning of the ignition plate to the point that the light turns on AT the LF timing mark. I'm a little concerned about how the engine feels as I turn it over though, and it seems to be acting differently than engines in videos I have watched.
As I approach the LF mark, I can feel the tension of the valve springs increasing, I have to push the wrench forward to rotate the crank. When the crank position reaches the LT mark and the piston begins its descent, it pulls itself down and instead of pushing against the wrench to rotate the crank, I have to pull against the wrench to prevent the crank from rotating.
Is this normal? There is no load on the engine, it's in neutral. Obviously this behavior makes it VERY difficult to guarantee that the coil is firing AT the LF mark, it's a moving target! A friend suggested I install the chain, put the engine in 5th gear, and use the rear tire to control the engine and prevent it from spinning the way it is. My concern is that something is awry inside and I don't want to add more parts to a bike that has to come back apart.
I hope my question is clear and I hope someone can give me some reassurance! Thanks!
