Compression test fine. Leak down test negligible. No compression = no squeak noise. What is this squeak noise and why can't I find it? I hooked up a leak down test and went through both compression and exhaust strokes and can't recreate the noise.
The last time this happened I was under the impression that the cam wasn't getting oil, I just don't see how that could be the case.
Compression leak, either a spark plug or a head gasket.
Discussion Starter #6
Nail on the head doode! Just found it. Was about to start doing higher pressure leak down tests when I found that thread. Intake boot at the top has a small leak and it’s squeaking. Thanks for the help everyone!
One member had something similar. Was the carb boots.
