I have a 72 cb350. The bike is definitely not running right. Backfired with any throttle and will not rev past 2000 rpm. Is it abnormal to see spark / arcing between the point contacts while the motor is running?
An occasional bit of arcing at the points seems to be normal. The symptoms you describe sound more like carburetion issues. Has the bike sat for a while?
A little sparking is normal, a lot of sparking or a big spark across the points is bad. If you can hear it crackle, it’s probably too big, imo. Usually means you’ve got a bad ground somewhere or your condenser is dying. I could see carbs on this one too, though not bad to make sure your grounds and condensers are good and your timing is behaving as expected. A dynamic timing gun would help rule out advance issues too.
