Please help. I’ve been trying for a long time to get my 1974 cb360 g5 to Idle nicely. (It’s actually a 250 but everyone ignores me if I say that, they’re the same bike almost).
I’ve stripped the carbs over 10 times and replaced all the parts I thought needed replacing/cleaned etc. I also put in new diaphragms. Then I discovered I had bad compression on the left side so I overhauled the top end and replaced rings and ground the valve seats, great compression now.. still no idle. I also replaced the carb manifolds on the cylinder head. I also put good hose clips on both sides of the carbs. I also put filters in my fuel lines. Plus a load of other stuff I can’t remember. NO IDLE. It seems fine when cold but always goes haywire when hot, sometimes the revs go up by themselves but most of the time it will idle high at 2000 + then die (unless I throttle). Getting a bit tired of it. Can anyone please suggest anything? Thanks, H
