Is S100 cleaner ok for our bikes?
I normally use some car wash cleaner w/warm water and a soft sponge, let it air dry and then wax with Mother's carnuba.
Noted a spot on my pipes that would not come out, even after polishing with Simicrome.
thoughts n' ideas? insert here:
Only an Admin. or Mod (or You) can edit into your post.... :D
I just used it all over the CB450 I bought, with no noticable bad effects. If you look at my thread in this category, you can see a picture of just using S100 cleaner and a water hose.
yeah, it's great stuff, I use it all the time.
severely diluted on painted bits
full strength to clean carbs (!)
washes off clean.
For carbs, i do a quick WD-40 spray after to coat surfaces as you're removing all grease, etc.
J
